PROBLEM
Synchronization fails for a checkout replica after certain geoprocessing tools are applied
Last Published: March 5, 2021
When geoprocessing tools such as Delete Rows, Delete Features and Append are used on data in a checkout replica, the features fail to synchronize with the primary geodatabase.
 This article only applies to ArcGIS for Desktop Standard and ArcGIS for Desktop Advanced versions 10.1 and prior.
Cause
This is a known limitation when certain geoprocessing tools are applied on replicated data outside of an edit session in ArcMap, since the tools do not track edits made to data in a checkout replica.
Solution or Workaround
Use one of the following solutions:
  • Use a different type of replica, such as a one-way or two-way replica.
  • Use these geoprocessing tools inside an edit session in ArcMap.
  • Upgrade to version ArcGIS 10.1 SP1 or greater, where the issue has been fixed.
Article ID:000012520
Software:
  • ArcMap 10 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
