ERROR
Unable to create a FeatureClass
Last Published: April 26, 2020
Error Message
Attempting to convert graphics to features in ArcMap via the Convert Graphics To Features command fails, and the following error is displayed:
"Unable to create a FeatureClass"
[O-Image]
Cause
Graphics can be converted into either feature classes or shapefiles using the Convert Graphics To Feature command. The error occurs when converting graphics to a shapefile and attempting to save the shapefile to a system folder, for example, Program Files.
[O-Image]
Solution or Workaround
Save the shapefile in the recommended default GIS location, instead of a system folder. The default GIS location to store the shapefile is:
C:\Users\username\Documents\ArcGIS
    Article ID:000012508
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
