English
Problem: Esri Maps for Office prerequisite installation repeats and the application fails to install
Before installing Esri Maps for Office, the installation process checks the system for various prerequisites and prompts to install any missing dependent applications. Once completed, the installer should proceed to install Esri Maps for Office. Instead, it goes back to the System Check window and prompts to install prerequisites again. The process repeats in an endless loop and never gets to the next step to install Esri Maps for Office.
Cause
Visual Studio 2010 Tools for Office Runtime files are missing from the system. These files are required to properly install Esri Maps for Office and are not automatically installed, and there is no documentation or warning about what supporting files are required.
Solution or Workaround
  1. Download and manually install Visual Studio 2010 Tools for Office Runtime from the following link: Visual Studio 2010 Tools for Office Runtime
  2. Proceed to install Esri Maps for Office.
