PROBLEM
The Register As Versioned option is disabled
Last Published: April 26, 2020
When attempting to register an SDE feature class or feature dataset as versioned in ArcCatalog, the Register As Versioned option disabled.
The Register As Versioned option is only available for ArcGIS for Desktop Standard and ArcGIS for Desktop Advanced licenses. This article is not applicable for the Basic license
Cause
This issue occurs if the connected user is not the data owner. Only data owners can register or unregister data as versioned.
For more information on user privileges, refer to the following documentation, ArcGIS Help: User privileges for geodatabases in SQL Server.
Solution or Workaround
Connect to the database as the data owner and register the data as versioned.
ArcGIS Help: Granting and revoking privileges on datasets.
    Article ID:000012497
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
