English
Error: Open of file "filename.kmz" failed: Parse error at line x, column y : not well-formed (invalid token)
Error Message
After converting a layer or map document to a KMZ file in ArcMap using the Layer To KML tool, the file cannot be opened in Google Earth, and a parse error regarding an invalid token is returned.
[O-Image]
Cause
This issue occurs because the layer name or one or more of the attribute fields are formatted incorrectly. There may be invalid characters such as "<" and ">" in the fields or the layer name. Because KML is an XML-based format, it recognizes these symbols as HTML tags. This causes Google Earth to be unable to read the field data.
[O-Image]
Solution or Workaround
Before converting the layer or the map document to KML, rename or remove invalid characters from the field.
Related Information
