English
How To: Create an ArcMap 10.3 startup log
Summary
These instructions describe how to create a startup log for ArcMap version 10.3
Procedure
Prior to running the following commands. The user running the commands must have full permission to the folder where ArcMap.exe is installed. The default location for ArcMap 10.3 is used in this example.
For other versions of ArcMap, the path may vary, for example, at version 10.2, this path is:
 <install location>\ArcGIS\Desktop10.2\bin
C:\Program Files (x86)\ArcGIS\Desktop10.3\bin
Please see your administrator for assistance with this.
  1. Navigate to Start > Run, type cmd, and click OK.
  2. Change the directory to <arcgis_install>\bin, and press Enter.
    If ArcGIS Desktop 10.3 was not installed to the default location, change directory to this location.
    Type the following path and press Enter:
    cd C:\Program Files (x86)\ArcGIS\Desktop10.3\bin
    image of command prompt window
  3. Type the following command and press Enter:
    arcmap.exe /log
  4. To view the log file, type the following command and press Enter:
    notepad arcmap.log
    The following is an example of an ArcMap startup log file:
image of log file
If the log does not write or ArcMap does not launch, it is most likely because the user does not have full permission to this folder. Please see an administrator for assistance with this.
Related Information
