HOW TO
Create a multiband raster from Landsat 8 band images
Last Published: April 26, 2020
Summary
A multiband raster from Landsat 8 band images can be created in ArcMap, either by using the Composite Bands (Data Management) tool or the Composite Bands button in the Image Analysis window.
The instructions provided also apply for compositing other raster datasets, to create a multiband raster.
Procedure
The instructions provided describe how to create a multiband raster from Landsat 8 band images.
Option A:
Use the Composite Bands (Data Management) tool.
1. In ArcMap, navigate to Geoprocessing > ArcToolbox > Data Management Tools > Raster > Raster Processing > Composite Bands.
2. Click the browse button, and search for the desired input raster.
[O-Image]
3. Specify the name and location of the output raster, and click OK.
[O-Image]
If working outside a geodatabase, specify the extension of the output raster.
Option B:
Use the Composite Bands button in the Image Analysis window.
1. In ArcMap, add the raster bands to the map document.
2. Navigate to Windows > Image Analysis.
[O-Image]
3. In the Image Analysis window, hold down the shift key and select the band images.
4. Click the Composite Bands button.
[O-Image]
The output of the Image Analysis window is added to the map document as a temporary layer. To save the output layer as a raster dataset, click the Export button on the Image Analysis window and specify the output location of the raster dataset.
The output raster of both options is generated as an RGB composite. To change it to a Stretched value composite, right-click the layer > Properties > Symbology. Under the Show section, select the 'Stretched' option, and specify the band to be used for the stretch values. Input the desired parameters, and click OK.
[O-Image]
Article ID:000012441
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
