English
Problem: The Measure tool is disabled in ArcMap
When accessing the Tools toolbar in ArcMap, the Measure tool is disabled (grayed out).
[O-Image]
Cause
This issue occurs because the map does not have known units.
[O-Image]
Solution or Workaround
Option A
Set the map unit of the data frame with a known unit such as Meters or Miles.
[O-Image]
The map units are determined by the data frame's coordinate system.
Option B
1. Specify a coordinate system to the data frame.
[O-Image]
2. After the coordinate system of the data frame is specified, the map unit is also set with a known unit.
The data frame's coordinate system is usually determined by the first layer added to the map.
For more information on changing and assigning a coordinate system, refer to the following ArcGIS Web Help topic, Specifying a coordinate system.
Related Information
