English
How To: Delete annotations stored in a map document in ArcMap
Summary
Instructions provided describe how to delete annotations stored in a map document in ArcMap.
Procedure
There are two ways to delete annotations from a map document:
  • Use the Select Elements tool to select the desired annotation:
    1. Click the annotation to be deleted.
    2. Press the Delete key on the keyboard.
  • Remove the annotation from the Annotation Groups tab in Data Frame Properties window:
    1. In the ArcMap menu, click View.
    2. Select Data Frame Properties.
    3. Click the Annotation Groups tab.
    4. Select the annotations to be deleted.
    5. Click Remove Group.
Related Information
