English
Problem: The Python parser in the Field Calculator returns incorrect results
In ArcMap, when the Python parser is used in the Field Calculator to carry out a division operation, integers are returned instead of decimals.
An example of the Python expression is as follows:
Code:
!VEHICLE_THEFT!/!POPULATION!
The division operation using the Field Calculator returns 0 for all fields.
[O-Image]
Cause
This is by design. Python 2.x is designed to return integers when dividing whole numbers regardless of the field type. For example, 1/9=0.
Solution or Workaround
In the attribute table, create a float type field. This allows Python to return a decimal in the result. After creating the new field, apply the Python script.
A. Create a new field type as float in the attribute table.
1. Open ArcMap.
2. Right-click the selected layer in the Table Of Contents, and select Open Attribute Table.
[O-Image]
3. Click the Table option drop-down arrow, and select Add Field.
[O-Image] [O]
4. In the Add Field dialog box, set the field name, and select Float as the field type.
[O-Image]
5. Click OK.
B. Apply the Python script.
1. Right-click the new field, and select Field Calculator.
[O-Image]
2. If a warning on calculating outside of an edit session displays, click Yes.
3. In the Field Calculator, type the script highlighted below.
Code:
float(!FieldName1!/!FieldName2!)
The code provided is for the input of the type float.
4. Click OK.
[O-Image]
    Related Information
