BUG
Migrate Storage tool drops the feature class when an error is encountered creating the spatial index
Last Published: April 26, 2020
The Migrate Storage geoprocessing tool drops the feature class being migrated if the process encounters an error when creating the spatial index. The issue only impacts feature classes stored in Oracle that are being migrated from compressed binary geometry to ST_Geometry. When the bug is encountered, the tool returns the following error message:
Code:
Executing: MigrateStorage 'Database Connections\Connection to TRUENORTH.sde\BOB.PARCELS' DEFAULTS
Start Time: Sat Feb 07 22:15:14 2015
ERROR 000955: Error encountered migrating the database storage of Database Connections\Connection to TRUENORTH.sde\BOB.PARCELS..
Underlying DBMS error [Error executing PL/SQL Block db_stgeom_create_index_by_schema::-ORA-29855: error occurred in the execution of ODCIINDEXCREATE routine
ORA-01654: unable to extend index BOB.S2$_IX1 by 128 in tablespace USERS] [BOB.PARCELS]
Failed to execute (MigrateStorage).
Failed at Sat Feb 07 22:19:21 2015 (Elapsed Time: 4 minutes 7 seconds)
When the error message includes the statement "[Error executing PL/SQL Block db_stgeom_...]", this indicates the tool failed when creating the spatial index and the feature class was dropped.
Executing the tool a second time returns a new error message:
Code:
Executing: MigrateStorage 'Database Connections\Connecton to TRUENORTH.sde\BOB.PARCELS' DEFAULTS
Start Time: Sat Feb 07 22:22:56 2015
ERROR 000955: Error encountered migrating the database storage of Database Connections\Connecton to TRUENORTH.sde\BOB.PARCELS..
DBMS table not found [ORA-00942: table or view does not exist] [BOB.PARCELS]
Failed at Sat Feb 07 22:23:00 2015 (Elapsed Time: 4.89 seconds)
Before performing a data migration, always create a backup of the database. For more information on migration requirements, see Data migration from one storage type to another.
Cause
The Migrate Storage geoprocessing tool is mistakenly dropping the feature class when an error is encountered creating the spatial index.
Workaround
This bug is fixed in the ArcGIS for (Desktop, Engine, Server) Migrate Storage for Oracle Patch. Download the patch, and follow these steps.
  1. Restore the database backup.
  2. Apply the above patch on the machine from which the Migrate Storage tool is run.
  3. Re-run the Migrate Storage tool.
Article ID:000012385
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
