HOW TO
Apply color to shapes in CityEngine
Last Published: January 8, 2022
Summary
Color can be applied to shapes in CityEngine by creating a rule file and using the color operation along with the appropriate RGB value or hexadecimal value.
Procedure
In this example, red color is applied to a 'lot' shape. These steps assume a CityEngine project is open with lot shapes in the Viewport window.
  1. Right-click the rules folder in the Navigator window. Select New > CGA Rule File.
[O-Image]
  • Add the following code to the rule file if RGB values are going to be used.
Lot --> color(255,0,0)
  • Add the following code to the rule file if hexadecimal values are going to be used.
Lot --> color("#FF0000")
  1. Save the rule file (File > Save).
  2. Apply the rule to the shape by dragging the rule file from the Navigator window onto the shape in the Viewport window.
[O-Image]
  1. Experiment with different colors until the desired result is received. Save the rule file after changes are made and select the
    Update Seed and Generate Models button to see the color updated in the shape: [O-Image]
Common Hexadecimal Values
Aqua = "#00FFFF"
Blue = "#0000FF"
Black = "#000000"
ForestGreen = "#228B22"
Gray = "#808080"
Green = "#008000"
Lime Green = "#00FF00"
Red = "#FF0000"
Yellow = "#FFFF00"
White = "#FFFFFF"
Common RGB Values
Aqua = 0, 255, 255
Blue = 0, 0, 255
Black = 0, 0, 0
Forest Green = 34, 139, 34
Gray = 128, 128, 128
Green = 0, 128, 0
Lime Green = 0, 255, 0
Red  = 255, 0, 0
Yellow = 255, 255, 0
White = 255, 255, 255
Article ID:000012362
Software:
  • ArcGIS CityEngine Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
