PROBLEM
Changing the symbology of imported point data changes previously imported point data symbology
Last Published: April 26, 2020
Using Import File to add points from a Microsoft Excel file to Business Analyst Online causes previously imported points to adopt the same color. This leads to difficulties in differentiating the points.
Cause
This is a known issue.
Solution or Workaround
  1. Select a symbol shape different from the original symbol when importing new points to Business Analyst Online.
  2. Click the drop-down menu next to the symbol and change the color of the symbol, then change the symbol shape back to the original shape. This gives the expected result.
Article ID:000012356
Software:
  • More Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
