PROBLEM
When designing a dashboard enabled with an Esri Map component, the SAP Dashboard commands for changing the stacking order of components cannot be used with the map; the Esri Map component must always be on the top of the stacking order.
The Esri Maps for SAP BusinessObjects add-on is an HTML5 web application that must sit at the top level of the dashboard’s canvas. The Esri Map overlay HTML covers the entire area of the screen where the dashboard designer has placed the Esri Map component. Regardless of whether the Esri Map component is moved to the back or the front of the canvas, the Esri Map overlay HTML covers all other overlapping components.
Get help from ArcGIS experts
Download the Esri Support App
