ERROR
Attempting to synchronize local edits containing true curves from ArcMap to ArcGIS Online displays the following error message:
Error:
"The local edits were not synchronized to the server. Cannot convert polylines or polygons with curves to JSON format."
This is a known limitation. The error occurs if the edits contain true curves; a true curve is a curve that only has two vertices as endpoints. Currently, ArcGIS Online does not support true curves created in the geometry of lines and polygons.
Get help from ArcGIS experts
Download the Esri Support App
