English
How To: Insert geometry from XY coordinates using SQL
Summary
In some cases, there may be a need to insert geometries into a feature class using structured query language (SQL). This can be done using a loop or a database cursor in SQL. Sometimes, due to performance, resources, or workflows, creating data via SQL is preferable to creating the data in ArcMap.
-- Get the number of rows in the looping table
DECLARE @RowCount INT
SET @RowCount = (SELECT COUNT(*) FROM sde.INPUT_TABLE)
-- Declare an iterator
DECLARE @iterator INT
-- Initialize the iterator
SELECT @iterator = MIN(OBJECTID) FROM SDE.INPUT_TABLE
-- Loop through the rows of a table @myTable
WHILE @iterator is NOT NULL
BEGIN
DECLARE @id as integer
EXEC sde.next_rowid 'sde', 'points', @id OUTPUT;
INSERT INTO sde.POINTS (OBJECTID, Shape)
SELECT
@id,
geometry::STPointFromText('POINT('+str(POINT_X, 38, 8) + ' ' + str(POINT_Y, 38, 8) + ')', 2286) as SHAPE
FROM sde.INPUT_TABLE where objectid = @iterator;
SELECT @iterator= MIN(OBJECTID) FROM SDE.INPUT_TABLE WHERE @iterator < OBJECTID
END
Procedure
In the example below, point geometry is inserted into a feature class from an existing database table.
  1. Create an empty point feature class in ArcMap using one of the following spatial types.
    SQL:
    Geometry
    Oracle:
    ST_Geometry
    SDO_Geometry
  2. In a SQL program, create a cursor or loop to iterate through the input database table. Create a geometry for each row.
    This procedure works best if a unique identifier column exists in the input database table, such as a rownum or OID field in SQL Server. This ensures the WHILE loop does not miss any rows that are not unique.
    To insert data into a registered feature class, a unique, not-null value must be specified for the ObjectID column. To do this, the Next_RowID procedure must be used.
    SQL Server Geometry sample:
    SET @RowCount = (SELECT COUNT(*)FROM sde.INPUT_TABLE)
    BEGIN
    SELECT @id,
    END
    Oracle SDO Geometry sample:
    SET SERVEROUTPUT ON
    -- Declare a cursor
    DECLARE
    CURSOR points is
    select *
    from sde.input_table;
    --Loop through the cursor
    BEGIN
    FOR pt IN points LOOP
    INSERT INTO SDE.POINTS (OBJECTID, SHAPE) VALUES (
    sde.gdb_util.next_rowid('sde', 'points'),
    MDSYS.SDO_GEOMETRY(2001,2286,MDSYS.SDO_POINT_TYPE(pt.point_x, pt.point_y,NULL),NULL,NULL)
    END LOOP;
    COMMIT;
    END;
    Oracle ST Geometry sample:
    SET SERVEROUTPUT ON
    -- Declare a cursor
    DECLARE
    CURSOR points is
    select *
    BEGIN
    sde.ST_Point(pt.point_x,pt.point_y, 2286)
    END LOOP;
    COMMIT;
    END;
Related Information
