PROBLEM
Bookmarks created in ArcMap do not import to a hosted web map in ArcGIS Online
Last Published: April 26, 2020
Bookmarks created in a map document in ArcMap fail to display when the map is published in ArcGIS Online as a hosted web map.
Cause
This is a known limit.
Bookmarks are created in a map document and stored directly in the map document JavaScript Object Notation (JSON), and are unique to a particular map document. They cannot be moved independently, and are not preserved in the web map.
Solution or Workaround
Re-create the bookmarks in the ArcGIS Online web map after the map is published.
See the link in the Related Information section below to learn how to create a new bookmark in ArcGIS Online.
    Article ID:000012309
    Software:
    • ArcGIS Online
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
