English
Bug: Raster layer with Vector Field Renderer displays blank in map service
When a map document includes mosaic datasets or netCDF raster layers that use the Vector Field Renderer, those layers display blank in a map service.
Cause
The Vector Field Renderer is not supported in map services.
Workaround
Use an image service to visualize data using the Vector Field Renderer.
  • Follow the steps documented in technical article 43439
