BUG
When a user runs the Patchfinder utility after installing ArcGIS-1022-E-PWMAS-Patch.msp, Patchfinder alerts that the Desktop version of the patch is installed. This is due to an incorrect registry entry made by the patch setup. This issue does not affect, in any way, the use of the Windows ArcGIS Engine software. The registry key is only there for the specific use of the Patchfinder utility.
The installation issue with the Windows ArcGIS Engine setup is caused by
BUG-000082730; When installing the PDF Web Mercator Auxiliary Sphere Patch for ArcGIS Engine, it is added to the registry with an ArcGIS Desktop Registry Key.
Get help from ArcGIS experts
Download the Esri Support App
