English
FAQ: Is it possible to hyperlink to UNC paths in an ArcGIS Online pop-up window?
Question
Answer
No, it is not possible to hyperlink to Universal Naming Convention (UNC) paths in an ArcGIS Online pop-up window. ArcGIS Online does not support UNC paths as hyperlinks.
However, ArcGIS Online supports the use of URLs (http://) in the pop-up window as hyperlinks. There are two ways to configure URLs in an ArcGIS Online pop-up window:
• Create a folder in the 'wwwroot' folder, and configure Directory Browsing with Internet Information Services (IIS) Manager. Refer to the solution provided in the following article, Problem: Unable to access hyperlinks in ArcGIS Viewer for Silverlight application pop-up, for more information.
• Use Custom Attribute Display when configuring pop-ups. Refer to the following blog, Crafting custom attribute displays in pop-ups, for further information.
Related Information
