BUG
The Parcel Editor's Regenerate command applies incorrect bearings to the radial lines of curves that have a central angle greater than 180 degrees.
These incorrect bearings can only occur if the initial release of ArcGIS 10.2.2 for Desktop Parcel Fabric General Maintenance Patch, dated 10-01-2014, has been installed. These incorrect values are written only if the Regenerate command is then run on parcels with curves greater than 180 degrees.
Get help from ArcGIS experts
Download the Esri Support App
