English
Problem: Unable to delete content from ArcGIS Online
Users are unable to delete items such as web maps, tile packages, hosted feature services, and tiled map services in ArcGIS Online.
Cause
This issue may occur when the Delete Protection option is enabled for each of the items in ArcGIS Online.
Esri introduced Delete Protection in the ArcGIS Online December 2013 update. Delete Protection is enabled to prevent items from accidentally being removed from the site.
Solution or Workaround
Before deleting items, disable the Delete Protection option for each item. Refer to the following blog post, Protecting your ArcGIS Online items, for more information.
Related Information
