ERROR
080002: The row contains a bad value
Error Message
In Business Analyst Desktop, when users attempt to geocode a table of addresses in an Excel spreadsheet using the Store Setup Wizard, the following error message is displayed:
"080002: The row contains a bad value.”
Cause
The error may be caused if the table of addresses in the Excel spreadsheet contains invalid characters.
Solution or Workaround
If the table of addresses in the Excel spreadsheet contains invalid characters, use the following steps:
1. Ensure the Excel table is formatted correctly. For more information on how to do so, refer to the following Knowledge Base article, HowTo: Format a table in Microsoft Excel for use in ArcMap.
2. Complete the geocoding process in Business Analyst Desktop using the Store Setup Wizard.
    Article ID:000012212
    Software:
    • ArcGIS Business Analyst Desktop
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
