English
Error: Error opening feature class. The feature class participates in a geometric network that could not be opened. DBMS table not found
Error Message
When opening feature classes participating in a geometric network, the following error occurs.
"Error opening feature class. The feature class participates in a geometric network that could not be opened. DBMS table not found."
Cause
The user has insufficient permission when accessing the feature class. To view or open the feature class in a geometric network, the user must have sufficient permissions to grant and revoke privileges on datasets.
Solution or Workaround
Grant the user with the required privileges to the dataset. To do so, please refer to the link below.
Granting and revoking privileges on datasets
Disconnect the multiple database user connections when performing administrative tasks to avoid creating database locks.
Related Information
