English
Error: Geodatabase schema object install not completed (-522)
Error Message
Using a full Oracle client to upgrade an Oracle geodatabase with the syntax ‘sde: oracle11g:TNSNAME’ returns the following error message:
“Cannot upgrade a user schema geodatabase when the master schema geodatabase is at a previous release. The master schema geodatabase must be upgraded first.
ERROR: Geodatabase schema object install not completed (-522)."
The error is returned in the sde_setup.log file (path: C:\Users\<username>\AppData\Local\Temp).
Cause
This is a known issue.
Solution or Workaround
• Change the connection syntax from ‘sde:oracle11g:TNSNAME’ to the Transparent Network Substrate (TNS) name in the Instance text box.
Type the TNS name in the Instance text box.
[O-Image]
or
• Modify the sqlnet.ora file on the client machine to connect to the geodatabase with the Easy Connect string, and upgrade the geodatabase.
    Related Information
