English
Error: 000229: Cannot open < value >
Error Message
When running a geoprocessing tool, ArcMap returns the following error message: “000229: Cannot open <value>.”
This error message indicates the data required by the geoprocessing tool is unavailable or invalid. However, the error message can display when the data is valid and accessible if background geoprocessing is enabled.
Cause
This error message displays when the following occurs:
• The data is inaccessible, unavailable, or invalid.
• There are unsupported data types in 64-bit background processing.
• Unsupported tools are unable to run in background processing.
• The 64-bit background geoprocessing does not have the necessary 64-bit libraries.
When background processing is turned on, scripts execute using 64-bit background processing. ArcMap is unable to read data types not supported by 64-bit background processing, while tools incapable of running in the background cannot leverage 64-bit processing. By default, ArcMap and ArcCatalog communicate through a 32-bit client library.
Solution or Workaround
Execute the tool in the foreground by disabling background processing, or uninstall 64-bit background geoprocessing.
  • Disable 64-bit background geoprocessing.
    1. In ArcMap, navigate to the Geoprocessing menu.
    2. Click Geoprocessing Options.
    [O-Image]
    3. In the Geoprocessing Options dialog box under Background Processing, uncheck the Enable check box.
    [O-Image]
    4. Click OK, and reload the tool.
  • To continue using background geoprocessing, uninstall 64-bit background geoprocessing. Background processing reverts back to 32-bit.
Related Information
