HOW TO
Setup an Xvfb display to use ArcGIS software through terminal services in a Linux or Unix environment
Last Published: November 24, 2020
Summary
Difficulties may be encountered when executing ArcGIS software through terminal services in a Linux or Unix environment.
The third-party MainWin runtime must have a valid display set, even when nothing is being directed to it.
The recommended workaround is to use Xvfb (X virtual framebuffer) to create a virtual display. The following steps describe how to do this.
Procedure
To setup a Xvfb display:
$ Xvfb :500 -screen 0 1280x1024x24 &
$ DISPLAY=":500.0"; export DISPLAY
The user should end the Xvfb process after finishing using the ArcGIS software.
Article ID:000012175
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
