English
Bug: After installing ArcGIS 10.1 SP1 QIP, maps are not visible in the Add Online Maps dialog when running ArcGIS on a non-English locale
After installing the ArcGIS for Desktop 10.1 SP1 QIP, maps are not visible in the Add Online Maps dialog.
Cause
NIM104373: After installing the Quality Improvement Patch for ArcGIS 10.1 SP1 for a localized Japanese version, there is loss of Japanese characters and a blank ArcGIS Online window appears.
This affects all non-English locales, not just Japanese.
Workaround
There is currently no workaround for this issue.
If this issue is encountered, please do the following:
  1. Download the file QFE-101SP1QIP-DT-295926.zip to a location other than the ArcGIS installation location.
    Make sure that you have write access to the ArcGIS installation location.
  2. Extract the patch QFE-101SP1QIP-DT-295926.msp, and double-click it to start the setup process.
    If double-clicking the MSP file does not start the setup installation, it can be started manually by using the following command:
    msiexec.exe /p [location of patch]\QFE-101SP1QIP-DT-295926.msp
