English
FAQ: Is it possible to filter feature services by date in an ArcGIS Online web map?
Question
Answer
No, it is not possible to filter feature services based on the date (for example, to show only certain features depending on the current date) in an ArcGIS Online web map. There is no built-in function to filter data in this fashion.
Filters cannot be applied on map notes or features imported from files.
However, it is possible to set a filter manually on the web map for hosted feature layers, ArcGIS for Server feature service layers, or ArcGIS for Server map service layers with associated attribute data. If users have a field in a feature class that designates a certain parameter, a filter can be set for the parameter before saving the map. Please refer to Apply filters for further information on filtering.
Related Information
