English
Bug: Relationships are not maintained after split of network features using ArcGIS 10.2.1 Utilities and Telecom Update 1 Patch
When splitting a simple or complex edge feature in a geometric network that has related records, the relationships are not maintained, i.e., dropped and not re-established, following the split operation.
This occurs when using the Split tool, Split command or the IFeatureEdit.SplitWithUpdate method when the ArcGIS 10.2.1 for (Desktop, Engine, Server) Utilities and Telecom Update 1 Patch is installed.
Cause
This is due to a NIM104364 - Relationships are not maintained after using the Split tool or IFeatureEdit.SplitWithUpdate with network features using ArcGIS 10.2.1 for (Desktop, Engine, Server) Utilities and Telecom Update 1 Patch.
Workaround
There is no workaround available for this issue. We have fixed the issue in the patch. Customers should download and install the ArcGIS 10.2.1 for (Desktop, Engine, Server) Utilities and Telecom Update 1 Patch, dated August 21, 2014.
    Related Information
