ERROR
lmreread failed: Invalid parameter. (-42,381:2 "")
Error Message
When attempting to run the 'lmutil lmreread' command for License Manager, the following error message is returned:
"lmreread failed: Invalid parameter. (-42,381:2 "")"
Installation of the ArcGIS License Server Administrator on Windows 2008 R2 or later produces the same error when running other License Manager commands, such as 'lmborrow', 'lmdiag', 'lmdown', 'lmhostid', or 'lmstat'.
Cause
This error is caused by the 'lmutil' being unable to find the license file due to enhanced security starting at Windows 2008 R2.
Solution or Workaround
To allow the 'lmutil' to run properly, insert an environment variable for ArcGIS License Server Administrator.
  1. Open Control Panel > System > 'Advanced system settings' to open system properties.
  2. Navigate to Environment Variables > New under 'System variables'.
  3. Enter the following:
    - Variable name: LM_LICENSE_FILE
    - Variable value: C:\Program Files (x86)\ArcGIS\License10.2\bin\service.txt.
Article ID:000012143
Software:
  • ArcMap
  • ArcGIS Data Reviewer
  • ArcGIS Workflow Manager
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
