English
Problem: Unable to display X and Y fields in the Display XY Data dialog box
After importing a table with latitude and longitude data from an Excel file into ArcMap, the X and Y Fields are not selectable in the Display XY Data dialog box.
[O-Image]
Cause
This issue occurs when the latitude and longitude field data types are incorrectly set.
Solution or Workaround
  1. In the Table Of Contents, right-click the Excel table, and select Data > Export. Browse to the specific location, specify the name (the default name is Export_Output), and save as type: dBase table.
    [O-Image]
  2. In the 'Do you want to add the new table to the current map?' pop-up, click Yes.
    [O-Image]
  3. Right-click the newly created table, and click Open to open the Table dialog box.
  4. Go to Table Options and select Add Field to add a new field.
    [O-Image]
    • Name: Longitude1, Type: Double
    • Name: Latitude1, Type: Double
  5. To start editing the table, navigate to the Editor toolbar and select Start Editing.
  6. When prompted, select the newly created table.
  7. Right-click the Longitude1 header and select Field Calculator.
  8. In the Field Calculator dialog box, double-click the pre-existing longitude field. Press OK.
    [O-Image]
  9. Repeat steps 7 and 8 for the Latitude1 field.
  10. Close the table. Save and stop the editing session.
  11. In the Table Of Contents, right-click the Export_Output table, and select Display XY Data.
  12. In the Display XY Data dialog box, select X Field: Longitude1 and Y Field: Latitude1 to specify the coordinates. Click the Edit button.
    [O-Image]
  13. Navigate to the desired coordinate system, for example:
    • Geographic coordinate system > North America > NAD 1983
Related Information
