Frequently asked question
The data type for a multivalue parameter in a Python script changed in ArcGIS for Desktop 10.1.
In ArcGIS Desktop 10.0, a multivalue parameter (a collection of items) was a ValueTable object. The following is an example of accessing a multivalue table name parameter in ArcGIS Desktop 10.0:
============ import arcpy tableList = arcpy.GetParameter (0) # a ValueTable object rowCt = tableList.rowCount arcpy.AddMessage ("rows: " + str(rowCt)) i = 0 while i < rowCt: # Get table name from list tbl = tableList.getValue (i, 0) arcpy.AddMessage ("table name: " + tbl) i += 1 ============
In ArcGIS for Desktop 10.1 and later, running the above code returns the following syntax error:
rowCt = tableList.rowCount AttributeError: 'list' object has no attribute 'rowCount'
The error occurs because the multivalue parameter is now a list object. An example of the updated code is as follows:
============ import arcpy tableList = arcpy.GetParameter (0) # a List object rowCt = len (tableList) arcpy.AddMessage ("rows: " + str(rowCt)) i = 0 while i < rowCt: # Get table name from list tbl = tableList[i] arcpy.AddMessage ("table name: " + str(tbl)) i += 1 ============
Get help from ArcGIS experts
Download the Esri Support App
