ERROR
EsriRegistrationMgr.dll is invalid or could not be found
Error Message
The error, “EsriRegistrationMgr.dll is invalid or could not be found,” occurs while installing ArcGIS for Desktop.
ESRIRegistrationMgr.dll helps to manage version information, but it does not affect any applications or server processes.
Cause
This issue may be caused by the following:
1. Files or a folder from a previous ArcGIS installation were not completely removed during uninstallation.
2. The related .dll files are missing, corrupt, or unregistered.
Solution or Workaround
1. Rename the ArcGIS folder to ArcGIS_OLD at the following location:
For 64-bit Windows operating systems:
• C:/Program Files (X86)/Common Files
For 32-bit Windows operating systems:
• C:/Program Files/Common Files
• C:/Program Files
2. Run the ArcGIS for Desktop installation.
Article ID:000012054
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
