Frequently asked question
Can multiple users edit a file geodatabase at the same time?
Last Published: March 22, 2023
Answer
Yes, it is possible to have multiple users edit a file geodatabase at the same time provided the users are editing:
  • Separate stand-alone feature classes at the root level.
  • Separate feature datasets (this is regarded as a workspace containing one or more feature classes).
If these rules are not followed, a schema lock error is received by all users editing the geodatabase, other than the primary user that locked the file geodatabase. If a file geodatabase is not editable at the current time, an appropriate message is received by the client application.
Article ID:000012031
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
