HOW TO
Install the Esri ArcObjects Visual Bean palette in Eclipse
Summary
ArcObjects developers who use the Eclipse integrated development environment (IDE) do not have drag-and-drop capabilities due to a known limitation in installing the ArcObjects palette as an Eclipse plug-in.
The Eclipse Visual Editor plug-in, which is a required dependency for the ArcObjects palette, has been deprecated. As a result, developers are not able to install the visual palette when installing the ArcObjects SDK plug-in in Eclipse.
Screenshot of error message when installing Visual Editor in Eclipse
[O-Image] VE install Error
Procedure
The ArcObjects SDK system requirements page advises developers to install Visual Editor prior to installing the SDK plug-in. However, this is only valid for older Eclipse versions as the Eclipse Visual Editor project is deprecated. The ArcObjects palette can be installed using the WindowBuilder plug-in.
1. Some versions of Eclipse are pre-installed with WindowBuilder. For versions without WindowBuilder, please follow the steps below to install it as a plug-in. In Eclipse, perform either of the two sub-steps:
a. Go to Help > Eclipse Marketplace, and type 'WindowBuilder' in the search bar. Click 'Learn More' to open 'WindowBuilder Pro GUI Designer' in Eclipse. Look for the download symbol
[O-Image]
in the top-right corner and click the symbol. Copy the URL shown, and set up an update site. Check the appropriate box to select the necessary plug-in(s) from the list of options presented. Proceed by installing the Eclipse plug-in.
b. Follow the steps for installing the new Eclipse plug-in and use the following URL in the 'location' field. Give the update site a name.
Screen shot of windowbuilder installation in eclipse
[O-Image]
2. Select the preferred options.
It is recommended that all options be selected and installed. In some cases, a failure to install some of these option(s) results in WindowBuilder becoming inactive in Eclipse.
[O-Image]
3. Start a new ArcObjects project (preferably a Basic Viewer). Right-click the BasicViewer.java file in the Project Explorer window and select Open With > WindowBuilder Editor.
[O-Image]
Installing the ArcObjects Visual Beans Palette in Eclipse
1. Activate the design view of the project and right-click the palette. Select the Import Jar option.
[O-Image]
2. Navigate to and select the 'arcobjects.jar' package. This is located in the respective folders in the Engine installation path or the Desktop installation path.
[O-Image]
3. Select the preferred Visual Bean classes (or select all) and give the classes suitable names after selecting "<New Category>" in the Category drop-down list. After clicking OK, the palette is installed and all visual components are accessible.
Eclipse visual palette with ArcObjects visual beans
[O-Image]
Article ID:000012030
Software:
  • ArcObjects SDK for the Java Platform
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
