English
Problem: Inserting a point of data in a map produces inaccurate results
When adding a point feature to a map in ArcGIS Desktop 10 by clicking in the map using an add-in tool or a COM component base tool, the coordinates of the newly created point are incorrect.
Cause
The coordinates are incorrect because they are currently screen coordinates, and not map coordinates.
Solution or Workaround
Convert the X and Y onMouseDown event arguments from screen coordinates to map coordinates using IDisplayTransformation::ToMapPoint(). The map coordinates use the coordinate system of the newly created feature’s feature class.
Below is a code sample based on the following link: ArcObjects Help for .NET
Code:
/// The code herein is based on the Add-In sample at this link on ESRI's Resources Website:
/// http://resources.arcgis.com/en/help/arcobjects-net/conceptualhelp/index.html#//000100000969000000
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
using ESRI.ArcGIS.ArcMapUI;
using ESRI.ArcGIS.Carto;
using ESRI.ArcGIS.Display;
using ESRI.ArcGIS.Geometry;
namespace AddIn_OnMouseDown_Tool
public class Class_OnMouseDown_Tool : ESRI.ArcGIS.Desktop.AddIns.Tool
// Module level variables
private IActiveView m_focusMap;
public Class_OnMouseDown_Tool()
protected override void OnUpdate()
Enabled = ArcMap.Application != null;
protected override void OnMouseDown(MouseEventArgs arg)
IMxDocument mxDoc = ArcMap.Document;
m_focusMap = mxDoc.FocusMap as IActiveView;
IPoint point = m_focusMap.ScreenDisplay.DisplayTransformation.ToMapPoint(arg.X, arg.Y) as IPoint;
System.Windows.Forms.MessageBox.Show(
"point.X = " + point.X + "\n" +
"point.Y = " + point.Y + "\n"
Related Information
