English
Problem: GeoPackage (.gpkg) is not visible in the Catalog view in ArcCatalog or ArcMap
When navigating to a directory that contains GeoPackage (.gpkg) data, ArcCatalog/ArcMap do not display them.
Cause
ArcGIS Desktop 10.2 has already been installed and Catalog used. Installing 10.2.1 or 10.2.2 does not show .gkpg files because the cache file is outdated.
Solution or Workaround
Delete the cache files (GxDBFactCache.dat, GxObjFactCache.dat) in:
%USERPROFILE%\AppData\Roaming\ESRI\Desktop10.2\ArcCatalog
This causes the cache files to be regenerated, and the .gpkg files are then visible.
