English
Error: No valid feature found in the received authorization data
Error Message
When authorizing a deployment license for ArcGIS Runtime, the following error may be returned:
"No valid feature found in the received authorization data."
Cause
The Software Authorization Wizard is having a problem writing to the keycodes file.
Solution or Workaround
Renaming the keycodes file before authorizing the license should resolve this issue. The steps are as follows:
  1. To locate the keycodes file, navigate to:
    C:\Program Files (x86)\ESRI\License10.1\sysgen
    or
    C:\Program Files\ESRI\License10.1\sysgen
  2. Rename the keycodes file to keycodes_OLD.
  3. Authorize the license in the Software Authorization Wizard again.
  4. To check the deployment licenses are working, open up LicenseViewer.exe at:
    C:\Program Files (x86)\ArcGIS SDKs\WPF10.1.1\tools
    For License Type, choose Deployment, there should be a string similar to:
    ArcGISRuntime.SetLicense("runtimestandard,101,RUD000000000,31-jan-2014,XXXXXXXXXXXXXXXXXXXX");
