PROBLEM
Globe Services crash on RHEL 6 Update 4
Occasionally, Globe Services crash on RHEL 6.4. When this occurs, the service crashes repeatedly and generates ldmps files in the following location:
<ArcGIS Server Installation Directory>/usr/logs/<Fully Qualified Domain Name>/errorreports
Cause
With Red Hat Enterprise Linux 6.4, the GLX extension is disabled in the Xvfb package (the X virtual frame buffer), and the rendering of the headless 3D applications fails to function.
Since Xvfb is required for ArcGIS Server on RHEL 6.x systems, this means that using the Xvfb as-is causes Globe Services to not work as expected.
Solution or Workaround
Log in to the Red Hat Customer Portal and request the xorg-x11-server patch if using ArcGIS for Server on Red Hat Enterprise Linux 6.4.
This problem does not affect other RHEL 6.x systems.
    Article ID:000011991
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
