Frequently asked question
Is it necessary to store the Dynamic Value table in the same geodatabase as the rest of the data?
Answer
No, it is not necessary to store the Dynamic Value table in the same geodatabase as the rest of the data; the table can be stored in a different geodatabase. The Attribute Assistant searches within the map document (MXD) to find the Dynamic Value table. It is not necessary for this table to be in the same geodatabase as the feature class or updated, stand-alone table; the Dynamic Value table functions in the current MXD.
Article ID:000011977
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
