BUG
Clipping a NetCDF raster layer using the Clip tool gives incorrect pixel values for the clipped output
Using the NetCDF raster layer as input to the raster clip geoprocessing tool gives incorrect pixel values for the clipped output.
Cause
This is a known issue.
Workaround
There are two workarounds to this issue:
  • Use the Extract by Rectangle tool (Spatial Analyst Tools > Extraction) on the NetCDF raster layer. This works fine and gives the correct pixel values for the clipped output.
  • Export the NetCDF raster layer into a permanent raster and use the Clip tool. This gives the correct pixel values for the output.
Article ID:000011962
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
