English
Problem: Map services fail to display on high resolution monitors
When viewing map services on a large high-resolution monitor, dynamic map services either fail to draw or do not display in the correct location.
Cause
This is due to the <MaxImageHeight> and <MaxImageWidth> parameters of the service being exceeded by the request.
Solution or Workaround
Increase the <MaxImageHeight> and <MaxImageWidth> values in the configuration. This allows the service to display on high resultion monitors.
Related Information
