BUG
MXD file names containing an ampersand (&) return the error, "Error! rasterizing data"
Printing to a plotter using the ArcPress Printer engine returns the following error, "Error! rasterizing data", when using an MXD file with an ampersand (&) in the name of the MXD file.
Cause
This is a known limit. The use of custom symbology (in this case, an ampersand) in the MXD file name causes the error to be displayed.
Workaround
Remove the ampersand from the MXD file name.
    Article ID:000011952
    Software:
    • ArcMap
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
