English
Error: ERROR 000539: Error running expression: rcexec()
Error Message
When running a Python script exported from ModelBuilder that includes a Raster Calculator function, the code fails because it is not able to run the rcexec() expression. The following error message is returned:
"ERROR 000539: Error running expression: rcexec()"
Cause
This error is due to Raster Calculator not being exposed to Python as a tool. Currently, Raster Calculator is only exposed as a geoprocessing tool in ArcGIS or in ModelBuilder. However, there are a number of different ways to use Raster Calculator functions in Python.
Solution or Workaround
This example shows how Python can use the Spatial Analyst Math toolset to perform mathematic functions on raster datasets, in a stand-alone script that can be run outside of the arcmap process.
  1. Open a Python IDE.
  2. Create a Python script using the Math toolset function.
    Sample using the Minus function:
    Code:
    # Name: Minus_Ex_02.py
    # Description: Subtracts the value of the second input raster from the
    # value of the first input raster on a cell-by-cell basis
    # Requirements: Spatial Analyst Extension
    # Import system modules
    import arcpy
    from arcpy import env
    from arcpy.sa import *
    # Set environment settings
    env.workspace = "C:/sapyexamples/data"
    # Set local variables
    inRaster1 = "degs"
    inRaster2 = "negs"
    # Check out the ArcGIS Spatial Analyst extension license
    arcpy.CheckOutExtension("Spatial")
    # Execute Minus to subtract inRaster2 from inRaster1
    outMinus = Minus(inRaster1, inRaster2)
    # Save the output
    outMinus.save("C:/sapyexamples/output/outminus.tif")
  3. Run the Python script.
Related Information
