English
FAQ: Where did the Move and Move To option go when editing topology?
Question
Answer
The options available in the Topology tool vary between versions. One of the changes was a simplified context menu for the Topology Edit tool.
When right-clicking the map with the Topology Edit tool in ArcMap 10.1, the menu shows only the most common tools. If any of the commands previously on this menu are needed, they can be added from the Customize dialog box. The instructions provided describe how to add the Move and Move To commands to the Topology toolbar in ArcMap.
  1. In an ArcMap session, click Customize > Customize Mode.
    [O-Image]
  2. In the Customize dialog, click the Commands tab.
  3. In the Show commands containing: text box, type Move.
  4. Under Categories, select Topology.
  5. In the Commands field, the options Move and Move To should now be available.
    [O-Image]
  6. Click the Move command and drag it to the Topology toolbar.
    [O-Image]
Related Information
