BUG
NIM093227: A reflected non-persistent cross-site scripting vulnerability exists in ArcGIS for Server 10.1 SP1
In one of the URLs that ArcGIS for Server 10.1 exposes, a reflected non-persistent cross-site vulnerability exists. This issue does not exist in ArcGIS for Server 10.2.
CVE Reference
CVE-2013-5222 Various XSS Vulnerabilities
Vector: AV:N/AC:M/Au:S/C:N/I:P/A:N Base Score 3.5
This vulnerability may be viewed as a standard entry in the Common Vulnerabilities and Exposures list
Acknowledgements
Esri thanks the following for working with us to protect customers:
  • Roberto Suggi Liverani of NCIA-NCIRC for reporting this vulnerability.
Cause
An attacker can use this vulnerability to run a script within the browser when viewing an Esri page using a specially constructed URL supplied by the hacker.
Workaround
This issue has been fixed in ArcGIS 10.2 for Server. Esri recommends that customers upgrade to the latest version of ArcGIS for Server.
For those customers that cannot upgrade, Esri has released a security patch that resolves this and other security vulnerabilities in ArcGIS 10.1 SP1. Customers should download and install the 10.1 SP1 Security Patch, which can be found here:
Article ID:000011863
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
