PROBLEM
Newly added cache scale is not available in the Manage Map Server Cache Tiles tool
After adding a new scale to an existing cache, it is not listed in the Manage Map Server Cache Tiles tool.
Cause
When adding a new scale to a cache using the Manage Map Server Cache Scales tool, it is also necessary to enable the new scale in Service Properties dialog box.
Solution or Workaround
To make the new scale visible in the Manage Map Server Cache Tiles tool, it must be added to the existing scale using the Levels of Detail slider bar.
  1. Open the Service Properties for the service by right-clicking the connection in ArcCatalog or in ArcGIS Server Manager.
  2. Under Caching, adjust the Levels of Detail slider bar to include the new scale.
    [O-Image]
Article ID:000011858
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
