Frequently asked question
Can Oracle Instant Client be set up to use a tnsnames.ora file when connecting to Oracle from an ArcGIS 10.1 or newer client?
Answer
Yes, as long as Oracle supports the use of a tnsnames.ora file with the Oracle Instant Client, it can be used when connecting from ArcGIS clients to an Oracle database. See the Oracle documentation links in the Related Information section below.
If both the 64- and 32-bit Oracle Instant Client are installed on the same machine, configure the TNS_ADMIN variable or registry setting to point both clients to the same tnsnames.ora file.
Article ID:000011850
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
