Frequently asked question
How is the specification of candidates returned from a geocode service?
Answer
When searching for addresses with a geocode service, the number of address candidates that are returned from the server can be configured by the settings in the geolocator service parameters. These address candidates are then sorted as described below.
• If the geocode service is set to return one candidate, then the candidate returned should be the best candidate.
• If the geocode service is set to return many candidates, then the returns should be sorted by locator and from the best candidate to the worst candidate.
• If there is a composite locator with three locators and nine matches are requested, then three sets of candidates are returned, sorted first by locator and then by score. If there are two locators, where "Locator A" returns two candidates and "Locator B" returns four candidates, then the candidates returned are two and four.
Article ID:000011825
Software:
  • ArcGIS Server
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
